(2)| 1/15/2025 6:34 PM | |
Joined: 6/11/2019 Last visit: 1/16/2026 Posts: 2722 Rating:
Hello Buttsy26
Somehow I can't quite follow your explanation. If you specify a temperature (setpoint), the control system determines the delay in the temperature. It usually doesn't matter how fast the valve moves. The actual temperature of objects or rooms is much more important. But if it's just about extending the analog value change for the output, then take a look at the picture or download the file. Regards Ella_68 AttachmentProgrammplan-1.zip (284 Downloads) |
