8/28/2025 11:22 PM | |
Joined: 11/4/2011 Last visit: 9/17/2025 Posts: 256 Rating:
The same problem with WinCC v8.1. The Manual says: If you do not authenticate yourself, the Audit components are opened read-only. But I have authenticated myself in Simatic Logon with the only user in Windows that is a member of "SIMATIC HMI AUDIT". Audit is the time-killing monster :( ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 08/29/2025 06:03:36New subject after splitting |
9/4/2025 5:49 AM | |
Joined: 8/3/2009 Last visit: 9/17/2025 Posts: 16447 Rating:
Hello TerminalBuzz Check also this information perhaps it helps: https://support.industry.siemens.com/cs/ww/en/view/109973507/176356301067 Bye Murof |
