(0)| 1/29/2010 5:25 PM | |
Joined: 9/19/2009 Last visit: 5/10/2025 Posts: 460 Rating:
Hello all. I have followed this Pdf to connect PC with Micromaster 420, but I can´t do it. I have message with an error. It is possible because the firmware is different or version. How I can know what version firmware I have? My Micromaster is this 6SE6420-2UC11-2AA1 XAR 708000156 ISSUE A04/1.17 "1.17 is the version?" Thank you. AttachmentMM4_Online_Starter.pdf (308 Downloads) |
If my answer help you, use the Thanks or Rate Button, It is free of charge :-) |
| 1/29/2010 6:24 PM | |
Ok !!! Thank you very much! I will check this parameter P2010! Set PG/PC Interface" is set to PC-Com Port (USS) this is correct! Regards JM |
| 1/29/2010 6:34 PM | |
Joined: 6/4/2008 Last visit: 11/25/2025 Posts: 1521 Rating:
Hi again, I guess if you are using a modern laptop, then you may be using a USB adapter, people sometimes have difficulties with these - see /tf/WW/en/Posts/37722 Cheers, Graeme |
