(0)| 3/13/2010 7:11 AM | |
Posts: 8 Rating:
Dear All I too facing the same problem when TD200 alone connected with S7-200 then message appears on TD that CPU not responding. But If PPI cable also connected parallel to TD and CPU network then TD works fine. I am using PPI USB Cable. Even if PPI cable is not connected to laptop, TD works OK. If PPI cable removed then TD stops working and give message CPU not responding. regards Subhash Agrawal |
Last edited by: O_Moderator at: 3/15/2010 10:19 AMLast edited by: O_Moderator at: 3/15/2010 10:18 AMnew subject after splitting from /tf/WW/en/Posts/12792#top |
