(0)| 5/31/2010 7:26 AM | |
Posts: 36 Rating:
HI DEAR, |
| 5/31/2010 8:26 AM | |
Joined: 2/6/2009 Last visit: 1/6/2026 Posts: 940 Rating:
Dearsaathiksye The below points to be checked whilecommunicatingwith a S7 200 CPU for the first time. > Always connect to Port 0. > Use only PC/PPI cable (not USB MPIAdapter) for the establishment of communication first time and after the initial setup you can use USB adapter. > Set the Baud rate to low. (9.6 KBPS ) > Keep the Communication Time out as high (30 / 100 Sec) If you have Simatic Field PG it is so easy to establish the communication. Revert Back for any clarification. |
_______________________________________________________________ |
| 6/1/2010 6:34 AM | |
Dearsaathiksyed, Vanakkam. Naan Tamil Nadu-lirunthu thaan .
I have attached the communication manual for the S7 200 system. I hope this will be useful for you. Revert back for any clarification. AttachmentS7 200 COMMUNICATION.pdf (254 Downloads) |
| 6/2/2010 6:15 AM | |
Posts: 217 Rating:
Hi, Check your CPU whether it is a Chinese one (CN). Thanks. |
