6/18/2010 8:21 AM | |
Posts: 12 Rating:
Hy everyone, If you enable the alarm (by calling the TD_ALM routine, with the correct bit) and you press acknowledge (Enter button), will the allarm disappear? or it will stay on until you stop calling TD_ALM. In the user manual it states: " When the operator presses ENTER, the TD device: ● Sets the acknowledgement-notification bit for this alarm. ● Clears the alarm-enable bit for this alarm. This causes the alarm to be removed from the display on the next update cycle" Hope someone has the answer. Splitted from Unable to activate alarms on the TD200!. |
6/22/2010 1:12 PM | |
Posts: 12 Rating:
Thnks Tomy, I apreciate your reply Regards |
