(0)| 4/22/2011 2:42 AM | |
Hello malkris; You do realize that the model of CPU you are looking at is quite old. It actually entered Product discontinuation phase in 1998: http://support.automation.siemens.com/WW/view/en/4069058 If you request technical data fron the appropriate tab, you will be told that there is none available. However, on the German supportsite, there will be some data available (in German of course, feel free to use Babelfish or some other online freetranslation service to give you the English version), http://support.automation.siemens.com/WW/view/de/4069058/td The closest specs I could find on my own harddisk date from 2002, and refer to a replacement CPU for the 416-2XL00, namely the CPU 416-2XK02 (look at the attached document, in the Technical Specifications chapter). Hope this helps, Daniel Chartier AttachmentCPU-Daten_e.pdf (455 Downloads) |
| 4/22/2011 6:49 PM | |
Posts: 2 Rating:
dcchartier, |
