2/2/2012 6:35 AM | |
Joined: 8/31/2010 Last visit: 10/15/2024 Posts: 1522 Rating: (228) |
Check this on - How can you access tags of the S7-1200 with WinCC?and then How can you establish a connection between an S7-1200 PLC and SIMATIC NET OPC? Also what is the Service Pack of the WinCC v7.0 you are using? |
Like it? Rate it! |
2/2/2012 6:41 AM | |
Posts: 7 Rating: (0) |
I'm using WinCC V7.0 service pack 2 Thanks |
2/2/2012 6:49 AM | |
If I want to write Scada for control the system ...This software can use ? If can't use,,, How can I do? |
