3/12/2012 6:37 AM | |
Posts: 39 Rating: (0) |
Dear friends, The timer proposed by nbkis initial time I use is ok, work well.( valvw1 and valve2 are 3s on, 6s off alternate)
But today i test again , Valve 1 only on, valve 2 is always off. I do not know, what happen. Please advise me. |
3/12/2012 7:41 AM | |
Joined: 1/28/2009 Last visit: 9/10/2024 Posts: 6849 Rating: (1365)
Dear ni lar, At least we should know how do you implement the codes.Upload you codes here and tell us about the reset mechanism.
Best regards, Hamid Hosseini |
3/12/2012 7:42 AM | |
Dear friends , Please see the attached file network 53 to network 56. And pls advise me. Thanks. Best regards, Ni Lar AttachmentOB1.pdf (242 Downloads) |
5/2/2012 4:16 AM | |
Posts: 621 Rating: (10) |
hi ni lar is it correct 3son,6s off timer program as suitable for your valves on off check it regards algudkar AttachmentFC1.zip (255 Downloads) |
8/17/2012 9:31 AM | |
Dear Friends, Please kindly advise for the following cause. The timer proposed by nbkis initial time I use is ok, work well.( valvw1 and valve2 are 3s on, 6s off alternate)
But now again , Valve 1 only on, valve 2 is always off. I do not know, what happen. So please advise how to solve this problem. Please advise me. Thanks & Best Regards, Ni Lar |
8/17/2012 11:08 AM | |
Hello, Please Upload part of project related to this section of your program.Also provide snapshots of online test. |
