(0)| 11/4/2012 12:24 PM | |
Posts: 3 Rating:
I have looked at the motor_Runtime_Ordering, Im trying to find a way, that when the 1 hour mark is meet, and the next motor is ready to run, how do you assign that byte to write the start signal into E.g. Motor start Block for it to be able to run, Im trying to use your hour run equlize to rotate the duty on my pump start blocks, but im trying to find out how. if you could help me this would be much appriceated Craigom I have attached a picture of my Pump start block, I need to known how you then enersise the bool tag DUTY. AttachmentPump Block.zip (753 Downloads) |
Last edited by: CS Moderator at: 11/5/2012 1:57 PMnew subject after splitting from /tf/WW/en/Posts/78434#top |
