2/5/2013 12:32 PM | |
Posts: 3609 Rating: (29) |
Import of a Technical Question of the user BrioCoco
6/25/2013 4:41 PM | |
Posts: 98 Rating: (6) |
Some sketch? |
6/25/2013 6:23 PM | |
Joined: 4/17/2012 Last visit: 8/30/2024 Posts: 474 Rating: (10) |
Hi , So simple u can connect any brand PLC with Wincc. Wincc is Supervisory Control and Data Acquasition System. it is like open software for all PLC makes and other than this it will work independently as a PC based automation system. Now the points considered for your process: 1. How many tags you need.(How much data you are going to take from each PLC) 2. Scalance is not a issue for your process consider 2nos of 8 port switch(SCALANCE) 3.RWF 40 i don't know about this. You have to tell which communication protocols it will support? if it support TCP/IP then it is so easy to communicate in common network. |
