1/2/2015 4:03 PM | |
Posts: 251 Rating: (11) |
Hello, thanks for your answer how can i find another motor code? which way i should follow? best regards
1/2/2015 4:54 PM | |
Joined: 9/27/2006 Last visit: 5/25/2024 Posts: 12257 Rating: (2668) |
Hello Juan; I can guide you to find the document provided earlier by techTeam, the procedure should be similar for other types of motors. Start by typing or copying the part number of your motor in the search box at the right of this page. The results page you will reach once you press the Search button will have a small section intitled Product-Links, where you will see the part number (partial or complete, that depends) as a link. if you open that link you will open the Siemens Product Support page for your motor (or motor family). Thereyou will see a a tab called Entries that you can open to fiond all available documents for this equipment (Manuals, FAQs, Downloads...), including Certificates (you can sharpen your search here by selecting the filter "Certificates" in the search header). Amongst the available certificates, look for the Test Report, and you will find this file: Test Certificates, Manufacturer certificate, Manufacturer Which is the file provided earlier. The sequence is detailed in the attached screencaptures. Hope this helps, Daniel Chartier |
1/5/2015 8:57 AM | |
Joined: 10/11/2006 Last visit: 5/23/2024 Posts: 5852 Rating: (793)
Hello JUANSANCHEZ, alternatively you can use my previous link, then click on "show the entry list" and then chose as entry type "Certificates". The "Type Test Certificates 2.2" are showing the data. If the motor isn't available in the list, please contact the customer support and open a support request. |
With best regards, |
