(0)| 4/10/2013 1:53 PM | |
Posts: 3037 Rating:
Hello Asw19flier, Which panel do you use? TP1500 Comfort or Basic You can create a HMI-project with a TP1500 in WinCC V11. Now you create in this project a PLC connection with the parameters of your 315-2 PN/DP PLC. Then you can communicate between your TP1500 and 315-2 PN/DP PLC which you created with STEP 7 V5.5. /tf/WW/en/Posts/75617 Tweety TIA Portal |
