6/20/2015 11:18 AM | |
Joined: 11/29/2011 Last visit: 8/19/2024 Posts: 1359 Rating: (232) |
Hi, You have to use the right expression. For example the method to write a bit into a word tag is described in WinCC V7.3: Working with WinCC under "Creating an Expression for Bit Data Types" on page 1047. You can see that you can actually specify what bit is your bool is connected to. There are other ways as well... I hope I could help! |
Last edited by: MicroMan at: 6/20/2015 11:21:06 AM- What you read here, please check with manuals and your requirements. |
6/20/2015 3:38 PM | |
Posts: 139 Rating: (0) |
my mean is writing hex value in the tag directly is it possible(mytag.write(FF))? or only decimal writing is true? |
6/20/2015 7:55 PM | |
Hi, Prefix? Use WinCC V7.3 Scripting: VBS, ANSI-C, VBA manual as reference. A lot examples and reference in it. Cheers |
Last edited by: MicroMan at: 6/22/2015 8:36:47 PM- What you read here, please check with manuals and your requirements. |
