(0)| 7/28/2016 4:44 PM | |
Joined: 6/3/2014 Last visit: 12/12/2025 Posts: 660 Rating:
Hello Ltsc, I guess you know the description of the method "GetStatisticResultColumn" in the manual already. https://support.industry.siemens.com/cs/ww/en/view/109096785/36145863691 I could imagine to use the "Export" method. It saves the values in a csv file. And because the structure is known you can select your desired values by script. So...
There might be an easy method, similar to the.value you tried, but I don't know it. Sorry. Edit: Maybe this works?
Maybe you can save the text in a string?
Last edited by: H.J. at: 7/28/2016 6:36:21 PM~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ★ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ |
