4/8/2016 1:14 PM | |
Joined: 12/28/2015 Last visit: 3/13/2024 Posts: 13 Rating:
Mr. ChristophD I have Siemens make 2 MPI cables. 1. PC ADAPTOR USB - 6ES7 972-0CB20-0XA0. 2. PC ADAPTOR USB A2 - 6GK1 571-0BA00-0AA0 I can communicate with 2nd one. but can't communicate via 1st one with same software and PLC. For USB A2 cable 'PG/PC interface'(in TIA portal) is showing "PC ADAPTOR USB A2" setting. But For 1st cable it's shows only "PLCSIM V5.x" in this setting. |
4/9/2016 2:49 PM | |
Thank you very much All.. For your kind and helpful responses and for check my problem.. The problem is solved now, by Re-installation of TIA portal V13.( I know It's not proper solution, but anyways my problem is solved.) Special thanks to ANKURGAMIT Thanks all again.
3 thankful Users |
8/27/2016 12:03 AM | |
Posts: 4 Rating:
hi
could you please tell me is that I need to install driver to use PC ADAPTOR USB - 6ES7 972-0CB20-0XA0. under windows 10 64 bit |
