11/14/2016 12:19 PM | |
Joined: 8/3/2009 Last visit: 9/8/2025 Posts: 16356 Rating:
Hello olmas-dev There is a possibility by using Adress Multiplexing. You could only use it with non optimized DBs in S71200/1500 and on S7300/400. Here is a FAQ to this function: https://support.industry.siemens.com/cs/ww/en/view/21808320 Its a FAQ for WInCC flexible but you could use it also in TIA portal I have used it many times an saved a lot of Powertags, Money and Time... Bye Murof |
