(1)| 1/5/2017 7:34 AM | |
Joined: 10/11/2006 Last visit: 1/20/2026 Posts: 6071 Rating:
Hello pj1995, Calculating the winder inside the S7-1200 you may use the Simatic Converting Toolbox https://support.industry.siemens.com/cs/de/en/view/58565043 - contact your local Siemens partner to get the software. Calculating the winder inside S120 (with DCC, engineering license is not needed if you don't want to change the DCC chart) you may use the DCC winder application, which provides also blocks for S7-1200 for control https://support.industry.siemens.com/cs/de/en/view/38043750 - you can download this application directly. |
With best regards, |
