2/16/2017 5:16 PM | |
Posts: 5 Rating:
Hello everyone, I am currently trying to set up a solution similar to that described on the FAQ Entry: I suspect that either the HMI device (KTP1200 Basic) or the TIA Portal version (V13 Basic SP1) I'm using does not provide this possibility. Does anyone know a possible solution or workaround? I am also considering recipes to solve my issue (dynamically loading a list of entries for the user to select from) but it is also not clear how I would go about loading recipe entries dynamically from the PLC. Thanks! Cheers, Edit: added hyperlink to FAQ Entry. |
