2/8/2017 9:36 AM | |
Joined: 4/28/2015 Last visit: 4/19/2025 Posts: 10876 Rating:
Hello, I can give you maybe quick test solution, you can use utility mentioned in this topic: https://support.industry.siemens.com/tf/ww/en/posts/communication-with-pc/161249/?page=0&pageSize=10 It's good application that can act as Server or Client with TCP or UDP protocol. With this application you can simulate your Server/Client in local network and test communication with S7-200. |
With best regards... |
10/4/2017 8:20 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8171 Rating:
New question published by watibe is split to a separate thread with the subject Communication between two old simatic step 7 PLC's S7-200 via cp 243-1 and cp 243-1 IT. Best regards |
