10/31/2017 10:24 PM | |
Joined: 2/22/2016 Last visit: 10/6/2024 Posts: 141 Rating: (30) |
Hi. We try to keep the communication in this tread for now. I don't think you can use the PAC4200 as a gateway, you should take a deeper look in to that. I started make a program, I belive it's a good starting point, but isn't finished yet. Take a look at it and try to understand it. I can help you finish it if you like it. To finish the program I need to know more about your network, like where the different devices are located. Attachmentrexhip.zip (114 Downloads) |
Last edited by: ola84 at: 10/31/2017 10:26:51 PMPlease use the contact form in the link below if you will like to come in contact with me. I don't check personal messages frequently. |
11/1/2017 6:17 AM | |
Joined: 9/28/2017 Last visit: 8/28/2024 Posts: 64 Rating: (0) |
HI ola84, Can you tell me why i can't use my pac 4200 as Modbus rtu to modbus tcp gateway for other third party devicees? The documents shows that pac 4200 can be used as gateway and there is a gateway option in the communication setting of pac 4200 modbus rs 485 expansion module. |
11/1/2017 6:29 AM | |
Here is some screen shoots from the pac 4200 manuals where the gateway function of the device is explained. check it out. Thanks. Regards Rakib. Attachmentpac4200_manual_screenshots.zip (86 Downloads) |
