12/18/2018 1:02 PM | |
Joined: 10/30/2012 Last visit: 3/26/2024 Posts: 73 Rating: (1) |
Hello, We are testing S7Comm with two S7-300 CPUs. Communication is working fine, but when we tried to use Wireshark and TAP104 for observation we encountered the following problem: We use Field PG M5 and TAP104: 1. When we capture P1 all looks good. 2. When we capture P2 all looks good also. 3. When we capture both P1 and P2 we have the problem shown on the attachment (Bad frames appear). If we filter tcp.analysis ack bad frames and retransmission we loose packets. For connecting with Field PG M5 and Wireshark we use the following procedure: TAP104 Procedure |
