2/9/2015 5:17 PM | |
Posts: 1 Rating: (0) |
Hello, I have the same problem, Have you find a solution?
2/10/2015 11:00 AM | |
Joined: 5/16/2014 Last visit: 9/12/2022 Posts: 7298 Rating: (2146)
Hello Sakbe Corona, have you already installed the Update 3 for WinCC V7.3, if not yet, you should do this, https://support.industry.siemens.com/cs/ww/en/view/108840240 If you would then have this behaviour futhermore, you should create a Support Request, and let investigate the behaviour by the Technical Support. Regards Georg Berghof
PS: If this post did really help you, you may use the Rate-button |
