12/20/2019 8:01 AM | |
Joined: 2/24/2012 Last visit: 5/11/2024 Posts: 2 Rating: (0) |
dear expert , can you please describe step by step that how we can interchange the mater /slave axis . we are using simotion d425 . we want to configure master axis as slave and slave axis as master. because in one machine our master axis component become fail and simotion not get healthy due to this. i am waiting for your positive response . please ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/20/2019 11:18:38New subject after splitting |
12/20/2019 10:12 AM | |
Joined: 10/11/2006 Last visit: 8/1/2024 Posts: 5883 Rating: (801)
Hello, when master fails, it makes no sense to make master to slave. Only make slave to master. 2.2.8 Switching of the master value source https://support.industry.siemens.com/cs/ww/en/view/109749950 When slave fails, stop on master mostly is the best thing. In case of high load inertia, it could be a solution to do a actual value gearing on defect axis position. Another possibility is to use a virtual Master. All axis synchronize on virtual Master. Real master has 1:1 gearing to virtual master. |
With best regards, |
