4/17/2020 5:19 PM | |
Joined: 9/27/2006 Last visit: 4/27/2024 Posts: 12257 Rating: (2665)
Hello kachkachuri; To document your problem, I first opened the Siemens Compatibility Tool, which generally gives you a overview of which software version can be used with different models of CPUs; your cPU is not part of their list. https://support.industry.siemens.com/kompatool/pages/main/index.jsf?sitc=wwdfi10002 Next, I looked up your CPU part number in the Product Support pages (use the search box at the right of this page to do the same): it is marked as Cancelled since 2004. See the screenshot below. The technical data of that CPU shows that is was designed to be programmed with Step 7 as per version 5.0. It might not be programmed or monitored with Ste 7 v5.6. Hope this helps, Daniel Chartier |
4/17/2020 5:28 PM | |
Posts: 9 Rating: (0) |
