6/23/2020 12:45 AM | |
Posts: 1 Rating: (0) |
Good evening. We have 2 PG M3, I managed to update the BIOS of both, but one is not installing the ME from Intel. However, the SP305 battery has not yet been recognized in both. Could you help me with what I should do to recognize the battery? The battery had been waiting for an update for 1 year. Version BIOS 14.01.07 - installed ME Intel - last version installed ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/23/2020 06:22:00New subject after splitting Last edited by: Jen_Moderator at: 06/23/2020 06:22:46Optimized headline. |
6/23/2020 7:18 AM | |
Joined: 10/18/2012 Last visit: 10/18/2024 Posts: 225 Rating: (23) |
Hello Gil_gsctec, sometimes recognizing the battery takes some time (minutes), especially when they are deeply discharged. I hope the SP305 battery is not damaged. In case you have a newer PG type (M4, M5...) you can try to charge the battery there. After the battery is charged you can put it back into your M3. It should recognize the battery now. If nothing helps - you may contact technical support. https://www.siemens.com/supportrequest/ regards, |
8/22/2020 11:17 PM | |
Posts: 4 Rating: (0) |
