11/19/2020 8:43 PM | |
Posts: 4 Rating:
Please, how can l get S7-200CN communication cable. Can every any other VGA cable do the same thing, in the absence of S7-200 cable?
Last edited by: Jen_Moderator at: 11/20/2020 09:58:49New subject after splitting |
11/19/2020 10:35 PM | |
Joined: 9/27/2006 Last visit: 9/13/2025 Posts: 12408 Rating:
Hello Elotechv; VGA cable? Here is a quote from a very recent reply I sent you on a similar subject: "You would also need a programming cable PC/PPI 6ES7901-3BF30-0XA0, or a PC Adapter USB A2 cable 6GK1571-0BA00-0AA0 to be able to connect your PC to the S7-200CN PLC." If you require official confirmation of this issue, I suggest you download and study the S7-200 System Manual. Except for the Chinese language settings, all information from the system manual applies to the S7-200CN CPUs. https://support.industry.siemens.com/cs/us/en/view/1109582 Hope this helps, |
11/20/2020 4:03 PM | |
Joined: 4/28/2015 Last visit: 4/19/2025 Posts: 10876 Rating:
Hello,
I'm very curios how you come to idea about VGA cable use. If you look to connectors and pins you can see clear and big difference. On other side this isn't only about cable wires, pins have some signals and also conversion due used protocol is required. All is also depended what port you can use on your PC, then due this info is very possible you will need completelly other comm cable. |
With best regards... |
