2/6/2013 2:37 PM | |
Posts: 3037 Rating:
Hello, You must copy your WinCC flexible project from your STEP 7 project. Then delete your WinCC flexible project in your STEP 7 project. If you delete your WinCC flexible project in your STEP 7 project, then your can not copy your WinCC flexible project from STEP 7 project. How do you integrate a WinCC flexible project in STEP 7? Tweety |
5/5/2020 10:22 AM | |
Joined: 9/26/2011 Last visit: 2/5/2023 Posts: 10 Rating:
In Simatic Manager try: File, Save As, With reorganization (slow) Solves many issues. |
5/6/2020 2:45 PM | |
Joined: 8/3/2009 Last visit: 9/12/2025 Posts: 16409 Rating:
Hello the Topic is very old but as an adition if you have problems with the integration of WinCC flexible in Simatic Manager then It could be that the Integratoin of the Project is defect. Then do the following: https://support.industry.siemens.com/cs/ww/en/view/80919613 Bye Murof |
