(0)| 3/8/2025 11:51 PM | |
Joined: 3/13/2019 Last visit: 4/27/2025 Posts: 196 Rating:
Dear sir, I am using Simatic V5.5 sp4 software and USB A2 pc adaptor to get online. I have set correct PG/PC interface but when i try to upload program no any error coming only it loading only for 2sec and disappear as attached in video. To overcome this problem i updated pc adaptor driver, also uninstalled Simatic manager but problem not solve. I have also checked drivers in devise manager under Simatic net usb pc adaptor A2 showing. My system specification is Windows 7 professional,32bit. AttachmentVID20250309042510 (1) (1).avi (309 Downloads) |
Last edited by: pankaj_054 at: 03/08/2025 23:59:56“In the middle of difficulty lies opportunity.” |
| 3/31/2025 6:55 PM | |
Joined: 9/21/2012 Last visit: 12/26/2025 Posts: 4829 Rating:
post a picture from both sides of your PC Adapter. |
| 4/1/2025 7:00 PM | |
Are you able to test another PC Adapter or another PC with that PLC? |
| 4/26/2025 11:12 AM | |
Dear all, After several trail i did not fixed problem i was facing the same problem so i uninstalled step7 v5.5 sp4 and tried to install it again but while installation random errors are coming every time. I also tried to remove all setup files from registry editor but problem is same. I have attached pictures of error....in addition to it 258:8 error is also coming. I also tried to install step7 professional 2010SR but it dose not successful. Pls share your thoughts... With best regards, Pankaj Tiwari Attachmentezyzip (4).zip (226 Downloads) |
| 5/5/2025 7:40 AM | |
Joined: 2/11/2015 Last visit: 12/18/2025 Posts: 515 Rating:
Hi Pankaj_045, From which PLC are you trying to upload? |
