5/24/2024 1:19 PM | |
Joined: 8/3/2009 Last visit: 6/14/2024 Posts: 13030 Rating: (1660)
Hello Hafiz_Ahmad You can use the CP that fits to your PC. in this Manual there is an example: https://support.industry.siemens.com/cs/ww/en/view/109824280/96369835915 As an alternative you can also use a CP343-1 and then you could use Ethernet Bye Murof |
