(2)| 6/17/2014 2:59 PM | |
Posts: 1299 Rating:
Hello, to solve the storage problem you can save the data on a shared folder in network and access this data with the comfort panel. See this faq: http://support.automation.siemens.com/WW/view/en/13336639 With an alarm you can open the needed document. If you use WinCC V13, you can load even pictures which are not used in the engineering.so you can change a picture during runtime witha script e.g. K!ke |
