(0)| 8/30/2024 10:33 AM | |
Joined: 11/9/2017 Last visit: 1/8/2026 Posts: 4 Rating:
Dear Sirs, We have broken CPU S7-300 315, when replace another CPU I don't have GSD file of HT401 handheld, can you help me send GSD file? we are very grateful to you.
Please help me file GDS KEBA HT401 KEBA00B3.GSD Thank you very much ------------------------------------------------------------------------------------------ |
Last edited by: AutoGen_2443909 at: 08/30/2024 10:35:03Last edited by: Moderator_Lan at: 08/30/2024 11:06:36New subject after splitting |
| 8/30/2024 2:53 PM | |
Joined: 7/7/2010 Last visit: 1/16/2026 Posts: 16379 Rating:
Are you saying you cannot simply power down the CPU S7-315, remove the memory card, remove broken 315, install replacement 315, install memory card into replacement 315, power up and get things to work?
science guy |
| 8/31/2024 1:54 PM | |
Hello; The KEBA site has a section they call Data Poral where they locate their Device Description files, including Profibus gsd files. Unfortunately, as you can see in the attached screenshot, they do not include files for the HT401. https://www.keba.com/en/industrial-automation/service-support/downloads/data-portal You have 3 ways of locating the gsd files for the HT401, in my experience: - post your enquiry on as many automation sites you can find on the Web and hope someone can provide you with this file. - Contact KEBA support and ask if they can send you the gsd file for the HT401. - Locate the original programming PC where the Step 7 program for this machine was saved, and look for the directory C:\Program Files\Siemens\Step7\S7DATA\GSD. This is where all the gsd files used in the program are saved. You can copy the gsd files from that directory and drop them in your new programming PC in the same directory, and then use them again in your program. Hope this helps, Daniel Chartier |
