10/3/2024 6:53 AM | |
Joined: 3/14/2008 Last visit: 10/4/2024 Posts: 2106 Rating: (940)
Hi, There are some rules regarding the synchronization behavior, see page 9 of the following manual (which is the latest version): Synchronization of individual control module types (PCS 7 V9.0 SP1) Furthermore, in my experience, the synchronization does not always work as expected, also with the use of variants where at least 2 or more blocks are inserted under a optional block. |
