3/8/2025 4:05 PM | |
Joined: 3/8/2025 Last visit: 4/11/2025 Posts: 2 Rating:
Hello, My siwarex cs use to give positive reading in piw4, now it starts with negatif reading -900, but it works normally. I changed it with other module and the new one gives positive reading. Is the module faulty ? |
Last edited by: aj_terfas at: 03/08/2025 16:07:50Last edited by: aj_terfas at: 03/09/2025 11:57:17 |
3/10/2025 11:13 AM | |
Joined: 1/4/2007 Last visit: 4/14/2025 Posts: 1186 Rating:
Hello aj_terfas, Well, what do you mean with ”it works normally”? Can you explain that a little bit more in detail, please. (I don't think, that the CS module is damaged.) Best regards Siwarexi |
3/11/2025 6:35 PM | |
when i calibrate the value, it gives accurate weight, the problem is why the module start giving negative reading in piw ? |
3/12/2025 8:56 AM | |
What do you mean with “calibrate the value”? What are you doing here? When you start the Siwarex CS, and you see -900: Which value do you see, when you put a test weight on the scale? Which weight has your test weight?
We are working on a new user interface with better overview and more relevance.
