8/19/2025 11:36 AM | |
Joined: 3/14/2008 Last visit: 9/11/2025 Posts: 2216 Rating:
Hi, As of PCS7 V9.1, a new block has been added to the AP Library called: "StrctCom""(FC396) which is a block that combines 32 bits to a structure. This block can be connected to the "Feature" structure of the desired block. PS: The block "StrctDeC" splits a structure into 32 bits.
