9/5/2006 2:42 PM | |
Posts: 10 Rating: (1) |
I have (EM 235 Analog 4 inputs/1 output) and PT-1000 termocoupl. can I read temperaturewith EM235 analog input by termocoupl. |
9/5/2006 3:02 PM | |
Joined: 4/24/2006 Last visit: 10/3/2024 Posts: 8744 Rating: (1168) |
Hello life, With EM235 you can use Current or Voltage inputs. But no PT1000 Perhaps when you use a convertor between PT1000 and EM235 you can get some signals in S7-200. But I think you can better use the RTD expansion unit. Here you can connect the PT1000. Just look in the manual: appendix A: http://support.automation.siemens.com/WW/view/en/1109582 Here is an explanation about EM235 and there you can find more information about EM231 RTD Hope this will help. Best regards, Wizard |
9/12/2006 3:27 AM | |
Joined: 9/12/2006 Last visit: 9/12/2006 Posts: 1 Rating: (0) |
you can find the detail solution in tips & tricks : http://www.automation.siemens.com/microset/html_76/support/tipps/tt-messtechnik.htm
Attachmentt36-e.zip (1043 Downloads) |
