11/17/2006 4:32 PM | |
Joined: 4/24/2006 Last visit: 11/6/2024 Posts: 8768 Rating: (1170) |
Hello, Here is a link to manual: http://support.automation.siemens.com/WW/view/en/1109582 On page 132 of PDF etc, you find description of High speed counter. And also a small example. Or you can look at the tips and Trics: http://support.automation.siemens.com/WW/view/en/1232912 Best regards, Wizard |
11/18/2006 9:23 AM | |
Posts: 47 Rating: (0) |
Deer Draxelmaier i thenk evry thing regarding HSC will be cleer for you if you read the links gevin by the golden member Wizard. but for your parteculer Qustions i till you 1- tha attached pectur is ok no falt Good..... 2-you are right the I0.0 will be taken autmatecaly to HSC0 and you dont need to assign it (only connect the wire comming from A+ of yor incoder)to I0.0 3- if you want to veu the reading of your pulse use MOVE instruction in Main Blok 4-pleas refiar to the sempel Exambel i attach and have alook to the Main Blok & HSC_INIT Best Regardes Essam Banat AttachmentHSC Sambel.zip (479 Downloads) |
11/18/2006 10:21 PM | |
Posts: 27 Rating: (0) |
Dear Essam & Wizard |
