2/7/2008 8:27 PM | |
Posts: 133 Rating:
Stuart, When you enter the key into 9920 index 0..9 it must be in Dec not ASCII. The key will be something like M3XB-VAK..... and converts into the index's as 77 51 88 66,,,,, You should then be able to change 9921 to a 1. Alwaysremember if you upgrade thefirmware in the CF to save your keys fileor you will overwrite it and loose the performance option. Also the Key is only good for that CF as it is attached to the serial number on the CF. You can use the license manager to get the key: https://workplace.automation.siemens.com/pls/swl-pub/swl_main_menu.navigation_head |
