Industry Online Support
1/16/2012 7:55 AM | |
Posts: 2964 Rating: (481)
Hello.... Looks like there is data loss...Check the battery voltage?? On CRT tube does the light glows ??? Check your power supply which is exactly below the monitor section... Ensure you should have your machine backups....afterclearing the data should be load back Check this link...detailed procedure is given for clearing and loading your backups /tf/WW/en/Posts/67619#top Regards, Prakash |
