2/22/2023 10:57 PM | |
Joined: 8/12/2021 Last visit: 6/11/2024 Posts: 309 Rating: (29) |
Hi Paul! It is possible to use only one PLC alone of an RH-system. But id you do so, you always project and configure both in TIA portal. Information on this special case can be found in the manual. |
