7/7/2025 3:31 AM | |
Joined: 7/27/2022 Last visit: 7/10/2025 Posts: 3 Rating:
Hi All, I need to run a siren using a SIMOCODE Prov V while using S7-1200. Its start address is Q6.2 and stop address is Q6.1. Ideally when it receives Signal 1 it should go off 3 times, if it receives Signal 2 it should go off 2 times and finally Signal 3 is received it should sound once. Any ideas how you can implement this using ladder logic? Thankful for the help! ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 07/07/2025 07:28:49New subject after splitting |
