4/22/2013 11:34 AM | |
Joined: 10/11/2006 Last visit: 9/15/2025 Posts: 6040 Rating:
Dear, regarding 1PH8 motors in general one can say: 1PH8 induction motors are the ideal drive for applications where the primary focus is on precise, smooth running characteristics and accurate controllability of the speed. They set themselves apart as a result of their cost effi- ciency, and supply high power ratings with the specified levels of precision. Typical application areas: • Machine tool spindles • Paper and printing machines, winders • Hoisting equipment and cranes • Woodworking, glass processing, ceramicsprocessing and stone-working machines • Test stands • Presses • Machines in the plastics industry • Textile machines • Wire-drawing machines 1PH8 synchronous motors are the ideal choice when it comes to high torque applications. Typical application areas: • Machine tools • Servo presses and cross-cutters • Printing machines • Extruders, calenders and rubber injection systems • Foil machines, non-woven systems, wire-drawing and cable stranding machines • Coiler and winder drives Find detailed infos in https://c4b.gss.siemens.com/resources/articles/e20001-a390-p630-x-7600.pdf |
With best regards, |
