3/3/2015 9:42 AM | |
Joined: 2/15/2015 Last visit: 8/29/2025 Posts: 11 Rating:
Hello, I have SIMATIC MICROBOX PC IPC 427C, in that there is a memory card which has 4GB capacity. If i want make backup for the PC, how can i take backup with new compact flash memory? How can i install windows XP and all other supporting software? pl suggest a solution. Sathish Venmani
Last edited by: Min_Moderator at: 3/3/2015 3:05:26 PMNew subject after splitting |
3/3/2015 3:58 PM | |
Joined: 5/12/2006 Last visit: 9/16/2025 Posts: 22710 Rating:
Hello,
for the IPC is a Tool available for Backup/Restore. With this tool you can create a USB Stick which you can use to make a Image from you IPC Flash Card and restore it to another Card. You can check if you can use another free Backup/Restore SW which boot from a USB Stick to do this task. With a Image you must not install the OperationSystem / Tools.
2 thankful Users |
