(1)| 4/17/2015 3:55 PM | |
Joined: 6/24/2013 Last visit: 11/14/2025 Posts: 1696 Rating:
Hi Assume Your weight is given as a Real in kg and You have a global Tick Count (use SFB at beginning of OB1 to transfer Tick Count to a global variable). You can try the attached code. FB400 does the counting FC104 is configuration The Tick count (used in FB400) is written to global variable by FB301 Edit Note: Added setup of time in FC104 Project attached (can be used in any PLC; not used clock bits can be removed) AttachmentDrop_counter.zip (209 Downloads) |
| 4/19/2015 10:53 PM | |
Joined: 9/1/2005 Last visit: 10/31/2025 Posts: 4114 Rating:
new question published by mbt2412 is split to a seperate thread with the subject help me out regarding this tonr timer FC 80
Best regards |
