(0)| 11/26/2018 4:58 PM | |
Joined: 8/25/2006 Last visit: 12/26/2025 Posts: 2221 Rating:
Hello. https://support.industry.siemens.com/cs/ww/en/view/109756832 |
| 11/26/2018 7:50 PM | |
Posts: 39 Rating:
Thanks for the link, but this is also the PCS7 version? I'm looking for the version only for Step 7, because with the PCS7 version all my projects are default set PCS7. See Default PCS7 topic. |
| 11/27/2018 6:02 AM | |
Hello. This happens when you install Step7 and CFC from PCS7-DVD running setup from the root of DVD. To avoid this: 1. Uninstall all Siemens SW. 2. Install ALM from DVD\06_ALM__V5.x\ALM64(32)\setup.exe 3. Install Step7 from DVD\09_STEP7__V5.x\Disk1\setup.exe 4. Install CFC from DVD\10_CFC__V9.x\setup\setup.exe 5. Extract CFC 9.0 SP2 from above link without installation. Open folder with extracted files and run setup.
| 11/27/2018 5:06 PM | |
Posts: 39 Rating:
thx! For a complete clean I also needed to clean the register (delete all Siemens stuff). I did install CFC V9.0 without SP, because SP2 must not be used with SIMATIC S7 F Systems according to the link. |
| 9/4/2023 7:24 AM | |
Posts: 1 Rating:
So helpful,Thank you! |
