Default Header
(0)| 2/17/2008 9:23 AM | |
Posts: 1 Rating:
discussed within the thread Working with ProTool Runtime and Simulator Hi.. I have to same problem about of PTProRun.ini.Please someone help me.while I m starting to ProToolPro RT always I encounter with some error.İts 'No configuration file was specified on the command line or in the 'PTProRun.ini' file Do you want to load a configuration file ??' what is this problem..How can I avoid to this problem. please someone help me,, best regards.... |
| 2/18/2008 4:48 PM | |
Posts: 1611 Rating:
Hi, i mean you did not have installed ProTool/Pro (maybe only ProTool or ProTool lite). Check this under the point "installed software" reagrds, |
