5/9/2024 2:54 PM | |
Joined: 7/4/2012 Last visit: 5/10/2024 Posts: 2 Rating: (0) |
Hello, I am trying to establish communication between an ET200SP CPU 1512-1PN (6ES7512-1DM03) with CM DP Module (6ES7 545-5DA00-0AB0) and an S7-316-2DP. I have downloaded the file from the corresponding link for the ET200S CPU + CM DP module which I integrated into step 7 of my S7-300. Unfortunately, it is not working. Error message with the GSD into STEP7 for hardware of S7-300: The type of plugged-in module differs from the configured one. Thank you for your help ! Link :https://support.industry.siemens.com/cs/ww/en/view/113652 |
Last edited by: allyouneed at: 05/09/2024 14:55:51Last edited by: Jen_Moderator at: 05/10/2024 07:49:53Link optimized. |
5/10/2024 6:13 AM | |
Joined: 7/9/2015 Last visit: 5/24/2024 Posts: 3848 Rating: (563)
Hi, there is a step by step manual - perhaps this helps you: How to you connect the communication module CM 1542-5 or the communications processor CP 1542-5 as I slave in STEP 7 V5.x to an S7-300/S7-400 CPU?Regards, Towome |
