(0)| 7/26/2025 3:22 PM | |
Hello JohnPeter; First, you should read this document about IEC 60780-5 communications with a S7-1500 CPU; there are similar documents for different CPUs, but the pronciples shown in the attachment below will remain the same. https://support.industry.siemens.com/cs/ca/en/view/109422039If you already have the RIC card for IEC 60780-5 in your CPU, then this document (for the Siprotec 7SJ80 will give you the points list for IEC 60780-5 communications. https://support.industry.siemens.com/cs/ca/en/view/109742651 Hope this helps, |
