2/14/2024 3:36 PM | |
Joined: 7/19/2022 Last visit: 5/17/2024 Posts: 358 Rating: (61) |
Hello GideonE, As far as I understand it is not possible to connect a passive output directly to the 6ES7232-4HD32-0XB0 module. I think Siemens does not have any module for passive outputs. Analog output modules would normally have separate power and signal connections. So you are going to need a signal converter. |
