4/23/2021 4:02 PM | |
Posts: 22 Rating: (0) |
Hello Everyone, If someone can clarify me about a problem ! To run a Runtime in TIA PORTAL in some laptop-device ,here must have only Intel 82579 LM ? I test 3 differed device with another communication board (ex:Realtek PCIe GbE ) and application in Runtime not working ! It must necessary to be only Intel 82579 LM ? Or,must to be done another setting somewhere ? Thank you in advance ! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/26/2021 09:26:50New subject after splitting |
5/7/2021 11:30 AM | |
Joined: 8/3/2009 Last visit: 5/24/2024 Posts: 12981 Rating: (1653)
Hello It should work with any network card. Check the Settings in here: https://support.industry.siemens.com/cs/de/en/view/89852595 especialy the PGPC Settings Bye Murof |
